Brad Russell
- Aug 13, 2003
I have a yamaha a-1 that I plan to add a separate amp(s) for either the fonts or the fronts and center channel. Thinking Outlaw or Rotel.
Currently I have a Crown D-150a at my disposal that used to run a passive sub. I believe it is rated at 125 stereo @ 8ohms. I'm thinking I'll sell it to help pay for the other amps. In the meantime I've been wondering about using it to power the front effects from my A-1. The A-1 is rated at 135 to the fronts and I think 35 to the front effects. So it would be a great boost to the front effects. I have heard that the Crowns have a tendancy to sound a little grainy and are therefore suggested to subs only. Anybody have an opinion? Should I use it to power my mains and re-route the front effects to the Yamaha amps? use the crown on the fornt effects? or leave it out of the system entirely? BTW I'm using Polk RT55s as mains and RT15s as front effects.
Thanks!
Brad
Thanks!
Brad
