Adding subwoofer to PC setup
Discussion in 'Speakers & Subwoofers' started by Shane Morales, May 11, 2004.
  1. Shane Morales
    Shane Morales Second Unit
    Jul 9, 2003
    433
    Wasn't sure where to put this because there are speakers, a sub, an amp, and a PC involved. I opted for here because my question is basically about a subwoofer. Please move this if I erred.
    I have a PC setup like so:
    2 JBL S38IIs
    1 Harman Kardon PA2000 amp
    1 PC with SoundBlaster Audigy 2
    Pics here
    I have a 1/8" stereo to RCA splitter similar to this from the sound card speaker out to the PA2000 with interconnects. Then normal speaker wire from the amp to the JBLs.
    What I would like to do is throw a powered SVS into the mix, but I'm not sure how I can do that. Do I have to pass the signal from the sound card to the subwoofer and then to the PA2000? Do I even need the PA2000 if I use the amp on the SVS for the JBLs?
    Thanks for the help.
  2. Nathan Bjork
    Nathan Bjork Stunt Coordinator
    Feb 7, 2004
    147
    Im not familiar with the H/K PA2000 amp, so does it have a sub pre-out?
    I setup a small sub to my PC speakers by using a homemade 1/8" mono to RCA, going from the audio "out" on my sound card into the RCA "in" on my sub. I had to set the crossover becuase it would send a full signal to the sub. Then I used normal PC speakers, connected the the PC speaker port on the back of my computer..
    If your amp has some sort of sub out then u could connect the svs like a normal AVR.
  3. TimRP
    TimRP Stunt Coordinator
    Feb 9, 2004
    115
    I think the pa2000 is just an amp, so no sub out on it. Here is what you do, connect the speaker level outs on the PA2000 to the speaker level ins on the sub, then the speaker level outs on the sub to your JBLs.
  4. Mike SJ
    Mike SJ Supporting Actor
    Nov 10, 2003
    718
  5. Nathan Bjork
    Feb 7, 2004
    147
    Or you could do that... duh
    I was still in thought of my little $50 sub
  6. Mike SJ
    Nov 10, 2003
    718
  7. Mike SJ
    Nov 10, 2003
    718
  8. Shane Morales
    Jul 9, 2003
    433
    I already got a sub! SVS PCi. Can't it drive the JBLs by itself? Soundcard to sub, sub to JBLs. Or, as Tim says, PA2000 to sub to JBLs. I'm kinda chicken to try things out cause I don't want to break anything.
  9. Robb Roy
    Robb Roy Supporting Actor
    Jul 15, 2002
    711
  10. Robb Roy
    Jul 15, 2002
    711
    Shane,
    Also, make sure you enable the crossover on the sub before you make those connections.
    -Robb
  11. Joey_V
    Joey_V Second Unit
    Apr 13, 2004
    354
    u got the svs eh? ur pc is closing in on my pc sound system! [​IMG] almost....
    enjoy the new sub - it will blow u away... literally.
  12. David*RT
    David*RT Stunt Coordinator
    Jun 26, 2002
    146
    Joey,
    That's quite a PC set-up you have there!
    I can just imagine playing Battlefield 1942 with that sub!
  13. Mike SJ
    Nov 10, 2003
    718
  14. Ron Daily
    Ron Daily Extra
    Aug 17, 2003
    21
    I love playing battlefield 1942 and other games with my pc set up. I have the output from the computer sound card going to my Onkyo TX-SR601 running a pair of polk RTI38's on 31" stands and a SVS 20-39 PC+ placed about 4 feet in the corner of my room. I just can't get enough of the sound of the ships guns being fired and impacting the ground. [​IMG][​IMG]
