Adding Memory
Discussion in 'Archived Threads 2001-2004' started by Chris-C, Feb 21, 2002.
  1. Chris-C
    Chris-C Stunt Coordinator
    Dec 7, 1998
    126
    Hi:
    I just added a 128mb chip to my HP laptop.
    The question is---Do I have to run an installer program? Or does it just start doing it's thang?
    Obviously i'm a little challenged in this area,so any help appreciated.
    I restarted the Laptop,and everything worked as before-with no noted mention of new hardware,so I assume it's a non issue?
    CC
  2. JohanK
    JohanK Second Unit
    Jan 22, 2000
    478
    W/ most computers, you will have to do nothing after the memory is installed. If your OS recognized the memory, you're good to go.
  3. Duncan Barth
    Duncan Barth Stunt Coordinator
    Apr 8, 2000
    60
    If you are running windows, right click on 'my computer' Select properties. The window that pops up should tell you how much RAM you have in your machine.
    If the amount listed seems right, you're good to go!
  4. Chris-C
    Dec 7, 1998
    126
    Thanks guys! You're the greatest!
    It does indeed show that I now have 256mb ram!!!!!!
    Regards
    CC
