Adding Infinity Crescendo CS 3007 to system? (1 Viewer)
System will be
Infinity Crescendo CS 3007 fronts
Infinity Sterling Video center channel
Infinity SL-30 rears
JBL northridge e250p subwoofer
Panasonic SA HE-75 receiver
I am hoping the crescendos will voicematch up to the other components you think this will work. Also the center channel is small and looks weak but it seems to hold its own on paper, would i need to upgrade it for these speakers? Also what would you guys recommend as a cheap receiver upgrade, something with 100x5@8ohms that is 6ohm capable if needed that isn't too much i don't need too many features just good clean power
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
Can you get us some links for the Infinity speakers? That’ll make it easier to give you an answer.
As far as a receiver, Yamaha makes some great stuff that’s more user-friendly than most.
Wayne A. Pflughaupt
They are older models here are some specs....
CS 3007
Recommended Power Amplifier Range: 30 - 175 watts/channel
Frequency Response: 45Hz - 35kHz (+/-3dB)
Crossover Frequency(ies): 450Hz, 3kHz
Sensitivity: 90dB (2.83 volts/1 meter)
Nominal Impedance: compatible with 8 ohm outputs
Woofer: 8" IMG
Midrange Driver: 4" IMG
Tweeter: EMIT-R
SL-30
Power Rating: 20 - 150 watts/RMS into 6 ohms
Frequency Response: 65Hz - 20kHz (+/-3dB)
Crossover Frequency(ies): 3.3kHz
Sensitivity: 92dB (2.8V/1 meter)
Nominal Impedance: 6 ohms
Woofer: 6.5" polypropylene
Tweeter: 0.75" ferrofluid cooled polycarbonate
Sterling Video Center
Recommended Power Amplifier Range: 20 - 150 watts/channel
Frequency Response: 58Hz - 20kHz
Crossover Frequency(ies): 4.5kHz
Sensitivity: 89dB
Nominal Impedance: Compatible with 8 ohm outputs
Woofer: 5.5"
Tweeter: 0.5"
the JBL sub:
12" driver
Nominal (RMS) Output Power 250 Watt
Max (RMS) Output Power 550 Watt
Response Bandwidth 25 - 150 Hz
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
The rule of thumb is that voice matching requires speakers from the same “family” or model line. More specifically, they’ll all have identical tweeters and matching woofers, or at least a smaller or larger version of the same woofer.
Voice-matching doesn't apply to the sub - you can use any one you want.
Wayne A. Pflughaupt
NHCondon
