Adding horn tweeters to my speakers
Discussion in 'Archived Threads 2001-2004' started by Ryan T, Oct 5, 2001.
  1. Ryan T
    Ryan T Second Unit
    Sep 10, 2001
    406
    Hi, I posted this topic in DIY advanced section except under A different name and got no helpful replies, I’m wondering if any of you guys could help, anyway here is my question. A while back I asked if Dome or cone tweeters where better. Every one said that dome tweeters are better of course, well I have two pairs of nice speakers I’m using for my sound system, the only problem is that they all have cone tweeters because there a few years old. I was going to replace the cones with domes but someone mentioned that the crossovers in my speakers where designed to work with each drivers specific characteristics and if I replace the tweeters that I could get very bad sound. Since buying new speakers is not really an option right now (I’m only 15 and don’t have tons of money to spend) I just decided I would have to make do with the cone tweeters. Well recently I was at radio shack and saw that they are selling horn tweeters, They do not require any crossover and since their piezo electric they don’t have any resistance. Here are some of their specs 100W RMS/200W max. 3800-30,00Hz. 92dB Sound Pressure Level 1W/1M. You can see a picture and a few more specs at radioshack.com, Cat.#: 40-1233. I'm wondering if I could put a horn tweeter in the back of each speaker box to expand the frequencies and to make the speakers dipolar or bipolar. My friend has some speakers setup exactly like this with a cone tweeter in the front and a horn in the back and they sound great. I could also use a potentiometer to control the loudness of the horns. Does anyone know if this would work? I'm also interested in any advantages or disadvantages there might be if I do this to my speakers.
    Ryan
    P.S. if you have any other suggestions to what I could do I would be happy to hear them.
  2. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    Wow.
    Ange Hamm and I recently replaced the tweeters in some old SONY bookshelf speakers that he's been using as studio monitors. His budget was similar to yours for this project. We tried those horn tweeters from Radio Shack and they sounded like TOTAL ASS!!!!! [​IMG]
    We brought them back and got the little cones. They sound much better. [​IMG] I would recommend against those particular tweeters. I took pics, they will be online someplace soon probably.
    Philip Hamm
    AIM: PhilBiker
  3. Andrew 'Ange Hamm' Hamm
    Andrew 'Ange Hamm' Hamm Supporting Actor
    Apr 7, 1999
    901
    Ditto. The horn tweeters sounded so terrible that they made us laugh out loud as if we were watching a clown juggling. We exchanged them (even swap) to much better effect.
    Andrew Hamm's new album Strange Education is available now!
  4. Ryan T
    Ryan T Second Unit
    Sep 10, 2001
    406
    Do you guys have any ideas as to what I could do instead of the radio shack horn tweeters? Is their better horns out there from like parts express or is the whole horn tweeter idea a bad one?
  5. Ryan T
    Ryan T Second Unit
    Sep 10, 2001
    406
    I’m wondering what tweeter you guys swapped the horn for?
    Was it the cone tweeter they have in many stores or was it some other tweeter? My other question is, are all radio shacks horn tweeters bad?
    Ryan
  6. MarkO
    MarkO Second Unit
    Feb 19, 1999
    309
    It not so much the fact that horns in general sound worse than conventional tweeters, but Piezo Electric drivers blow chunks.
