David Lawson
I have one pair of Aura 25w shakers that I want to add to a Kenwood HTB-354 (which does exist, despite the fact that it's nowhere to be found on the Kenwood site). It includes the VR-517 receiver, which looks to be pretty similar to the VR-506 currently on the Kenwood site.
I'm wondering what would be the best way to go about adding the shakers. I really have no clue when it comes to power output, impedance, etc. The HTB-354 includes a 100-watt powered subwoofer, but I fear I would exceed the wattage limit by running the shakers through/off the subwoofer.
I've seen a few posts here that suggest using a second receiver to power the shakers, but I'm wondering if an old stereo amp would be a cheaper (and space-saving) alternative. I've also seen suggestions that the shakers should be run in series, which I think means that the two shakers will be connected to each other and driven on the same channel. In that case, I would only need one additional channel capable of driving 50w (25 x 2) at 8 ohms, correct? Are there 50w mono amps/receivers out there?
I'd like to do this as inexpensively as possible, considering that I had to go with an HTiB in the first place, and they're only shakers...
Thanks in advance.
Link Removed
He obviously misinterpreted what it means to "be bullish."
Thanks in advance.
Link Removed
