Adding amp, couple of ??'s
Discussion in 'Archived Threads 2001-2004' started by RobG, Jan 10, 2002.
  1. RobG
    RobG Stunt Coordinator
    Jan 22, 2000
    51
    I am adding an amp to my HK AVR300. I am guessing I need 5 coax cables to run from the rec. to the amp. Are these a special type of cable? Should I plug the amp into the switched plug on the rec.? I assume I will need to re-calibrate, is this correct? Any other helpful info is appreciated.
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,098
    33
    Katy, TX
    Wayne
  3. RobG
    Jan 22, 2000
    51
    Thanks for the info. One more question; should the amp be plugged into my power strip/conditioner or right into the wall? Thanks again.
  4. Kevin T
    Kevin T Screenwriter
    Jul 12, 2001
    1,402
    some people will say straight from the wall is the only way to do it. when i used an acurus a200x5, i connected it to a monster hts-2500 and then tried it straight from the wall for comparison and found no noticeable difference. i say go for the surge protector for the added safety unless you unplug after every time you turn your system off. of course, ymmv.
    kevin t
  5. Drew Eckhardt
    Drew Eckhardt Stunt Coordinator
    May 10, 2001
    246
    You do need to recalibrate because there's no guarantee the new power amplifier gain matches that of the internal amps.
  6. RobG
    Jan 22, 2000
    51
    Can't wait to get it all hooked up. Thanks again.
  7. Legairre
    Legairre Supporting Actor
    Apr 4, 2000
    815
    I did need to re-calibrate after adding a 200x5 channel amp. I'm plugging my amp right into to outlet, but I do plan on getting a PS Audio Ultimate Outlet(20 amp version). Just to make sure I don't starve the amp of the power it needs.
  8. RobG
    Jan 22, 2000
    51
  9. Legairre
    Apr 4, 2000
    815
