Robbie R
- Sep 14, 2004
I have a few questions about adding a separate amp.
My current set-up is:
Rotel RSX-1065 Receiver (5X100)
B&W 603S3 Fronts
B&W LCR 700 Center
B&W 601S3 Rears.
I am considering these 2 options.
1) Buying a used Bryston 3B-ST (2X120)for the mains only.
2) Buying a New Rotel RMB-1066 (6X60) and bridging the amp to output 3 X 150.
If I buy the Bryston used they should cost roughly the same amount of money.
I really like the idea of the Bryston because it will sound great for stereo music, but I am worried about not having the same amplification up front for movies.
This is why I am considering the Rotel RMB1066 bridged to 3X150. BUT.... are their any drawbacks do using an amp bridged?? will it affect the sound??? Can I set it up myself or does the dealer do it when you buy it. I don't have a clue how it works. (any advice on this would be greatly appreciated)
What do you guys (and girls) think? Would you go with the Bryston or Rotel?? Or should I be looking at something else??
I have about $1000.00 CAN$ to spend. My usage is 75%Movies & Gaming, 25%Music.
Thanks Rob
B&W 603S3 Fronts
B&W LCR 700 Center
B&W 601S3 Rears.
Thanks Rob
