This may be a stupid question (I'm new), but can I add a rear center speaker to my 5.1 system some how??? Can this be done with just a simple wiring solution or do I have to buy more equipment???
You would still need a preamp/processor or receiver to decode the center surround channel. You could also look into separate stand alone center surround decoders like the CS-3x jr made by ADA. I hope I called it the right thing.
James,
Good question, not stupid!
Here's what you do.
(BTW, this is called Dolby 6.1 ES)
Go from left and right Surround Outs on your reciever to line in on a Dolby Pro-logic Processor or reciever and plug an extra center in there.
Select the Pro-Logic function on your pro-logic reciever and hear the extra rear go!
For more info (from smarter people) just do a simple search on HTF for DIY 6.1 or Dolby 6.1
Good Luck,
Nathan
James: you also must have rear channel pre-outs on your current receiver. If you want to try it, I'd look for a used inexpensive Dolby Pro Logic surrround Processor. That way, if you don't like it, you haven't spend a couple hundred bucks.
