Adding a rear center...1 speaker or 2 ??
Discussion in 'Speakers' started by dan-0, Aug 7, 2003.
  1. dan-0
    dan-0 Stunt Coordinator
    Aug 1, 2003
    156
    I'm currently in my once every ten years HT upgrade mode.
    Just bought a Denon AVR2803 and now need to upgrade the rear surrounds and add a rear center.
    I've decided to go with either used NHT super zero or new NHT super zero XU for the rear surrounds. I see that NHT sells the speaker by the one. Can I get by with one matching speaker for the rear center, or should I use two more NHT's for the center. Or, are there options for mounting a more traditional center speaker for the rear (would like to keep it kinda small though). All rear speakers will be wall mounted.
    Thanks in advance
    dan
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Ideally you'd want two rear centers. But don't shortchange your main surrounds in order to accomplish that, if at all possible.
