Nathan_J_A
- Sep 30, 2003
Hi Everybody,
I've posted the meat of this at a couple other forums, but I've been trying to get access to as many people with applicable experience to my situation as I can.
I've essentially decided on two possible upgrade paths, but not being able to hear Rocket's without buying them, or knowing how they'll blend into the rest of my stuff is kind of a hitch at the moment. The nearest Rocket auditioning I can go to is at least four hours away on the other side of the state. Anyway... hopefully I'll be in a position to do the following.
I will be selling off my Def Tech ProCenter C2, and I will be moving my current front Def Tech BP8-B's to the rear to use as "rear" surrounds mated to my already established Def Tech BP8-B "side" surrounds.
This means I'll need to get two new main front speakers, and a new center channel speaker.
I'm hoping to get a hold of one of these two setups:
Left/Right: Rocket 750's
Center: Rocket 200
...or...
Left/Right: Def Tech BP30's
Center: Def Tech C/L/R 2000
It's a tough choice, and the cost of each setup is virtually identical. I can probably go a bit cheaper with the Def Tech's because of the relationship I've built with my local dealer.
I'll be driving everything with my NAD T762 receiver, and possibly a dedicated Marantz MA200 monoblock amp for the center channel. Or finances permitting I may trade-in my T762 for a T163 pre/pro and try to land a good deal on a Sherbourn or ATI seven channel amp.
I'm just grossly unsure about either route.
As it stands I lean either way depending on the day. I've also been doing some measurements, and I might be able to replace the whole Def Tech setup with the Rockets by replacing the side and rear BP8's with RS550's. It'll be a tight fit on the side speakers though, and so it may be hard to give the speakers more than a couple inches from the wall for the ports to breathe. Now if the RS550's were FRONT PORTED (are you listening ONIX ) then it wouldn't be an issue.
My biggest concerns are shrinking my soundstage by moving back to monopole speakers, and then of course if I can't go to an all Rocket setup will having just the 750's and the 200 upfront clash too much with the Def Tech's? Then there's always that little voice inside that keeps wondering if Rocket RS750's are even really much of an upgrade over Def Tech BP30's.
Anyway I'd love to hear the who, what, and why from people who moved from Rockets to Def Techs, from Def Techs to Rockets, from people who considered both and picked one, or even those who considered both and opted for something else.
I'd love to just order the Rockets and give them a try, but if they don't work out I'm going to be a wee bit peeved at forking over $120 to get rid of something I might have known I didn't want in the first place if I could audition them. Unfortunately there aren't very many people in Spokane who spend $2000+ on speakers.
Thanks a bunch,
-Nathan
Center: Rocket 200
...or...
Thanks a bunch,
-Nathan
