Add damping material to front wall? (1 Viewer)
jeff peterson
Do I recall correctly that it's a good thing to add some damping material behind each front speaker as well as behind the center and/or TV?
I know we should on the side walls at the point of first reflection.
Frank_S
Jeff, you are correct, however the choice of material and the amount of damping or absorption is important. I can't say I know much about this subject but I'm learning. A great source for this info is on another site I peruse.
www.audioasylum.com Check out the tweaks section and perform a search under "wall treatments". There is a plethora of info regarding this topic and there are some very nice DIY projects there also. Good luck!:)
AlohaTiger
