Jake Garian
- Sep 10, 2002
I have an Adcom GTP-450 stereo-only preamp with an "External Processor Loop" L/R in/out. It is not discussed in the manual.
I assume it is a signal-level loop for adding an EQ or something similar?
Is it a constant level signal or is it controlled by the volume setting?
If it is inline with the primary signal path, I can't understand how it can be an open loop by default - ie. the ins/outs are not currently connected but the preamp works fine.
Any clarification would be appreciated. Thanks.
