Adcom 535 Power amp
Discussion in 'AV Receivers' started by davidLL, Jul 2, 2006.
  1. davidLL
    davidLL Auditioning
    Jun 24, 2006
    3
    Just purchased used Adcom 535 amp and am using it to power Niles outdoor speakers. Unit has A/B speaker switch. Didnt receive amp yet but was wondering if I will be able to play same source material inside while also listening to it on outdoor speakers. I own Marantz SR19 receiver which is multi room capable. On another note, I am powering Martin Logan Aerius 1 Speakers which are rated 80-200 watts at 4 ohms. Receiver puts out 110 watts per channel on front,center,and rear. Would a separate amp significantly improve sound on front speakers for music listening which is what I mostly use system for? Thanks for any input !
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,098
    33
    Katy, TX
    Wayne
    That depends on your receiver – it doesn’t have anything to do with the Adcom amplifier. Your owners manual will answer the question.
    Wayne A. Pflughaupt
