Acurus power switch LED problems
Discussion in 'Archived Threads 2001-2004' started by Brian Perry, Jul 26, 2002.
  1. Brian Perry
    Brian Perry Cinematographer
    May 6, 1999
    2,807
    I have three separate Acurus power amps (two 200x3 and one A150) and the green light on the on/off switch has gone bad on all three. (They start to flicker, and then go out altogether.) I'm not even depressing the switches -- they are always in the "on" position and the amps are sequenced on by my Panamax power controller.
    I have had one replaced by my dealer, but I don't feel like going back for what seems like a temporary fix. Does anyone know if these Acurus switches are known to be bad? (The amps work fine otherwise.) Would it be easy to replace them with other, more reliable, LEDs?
  2. Rob Rodier
    Rob Rodier Supporting Actor
    Jul 11, 2002
    538
    The leds are known for going bad. I have seen and heard of it MANY times. Last I heard, mondial was fixing them for free, but you need to get the unit to them. AS for replacing, I don't think you are endangering anything. I understand it is annoying but if something has to burn out on the amp that is everyones first choice. [​IMG]
    Great theater you got!
    -rob
  3. Brian Perry
    May 6, 1999
    2,807
    Thanks Rob!
  4. Craig Woodhall
    Craig Woodhall Supporting Actor
    Jul 11, 1999
    590
    Brian,
    I emailed mondial tech support and the sent me a new one from the factory.. I had to pay the $15 for it but it has been fine since.
    Craig
  5. Kevin P
    Kevin P Screenwriter
    Jan 18, 1999
    1,439
    If it's a LED it sounds like they're feeding AC into the LED--a design flaw that will make an LED fail in short order.
    The LED should be supplied from a DC source. Then it'll last nearly forever.
  6. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    It's not the power supply to the LED that is the problem. It's the LED itself. I had two fail, 1 on a 100x3 that I sent back that they fixed for $95 I think (I had them check out the entire performance of the amp as I got it used), and 1 on a 200x3 I got later on.
    The replacement LEDs are a different type and manufacturer than the original, and neither have failed years later.
    BTW, they sent me the LED for free, but that was a while ago! [​IMG]
  7. Kal
    Kal Agent
    Jul 27, 2002
    33
    Were they actaully LED's or little neon's?
    I bought a couple of Acurus amps from the older line back around 1997 that used neon lamps that tended to flicker and just plain stop working. Turns out that a new line has just been introduced (mostly cosmetic changes) that used green LED's instead. I swapped them in for the new line and they've been fine for the last 4-5 years.
    You have me worried now that the LED's are going to go on me... [​IMG] Are your amps like the ones in this photo?
    [​IMG]
    Kal
  8. Kevin C Brown
    Aug 3, 2000
    5,712
    As to the distinct type of LED, all I know it that they were green! [​IMG]
    Plus, a little more detail: I had a 100x3, LED failed. Over a period of about 3 years, I went through 3 200x3's (long story; nothing wrong with the amps), and 1 of those LEDs failed.
    Because I liked Acurus so much, I *now* have 2 A200x3's (for a 6.1 system). The A200x3 has a different type. I haven't had any of those fail. And in fact Acurus/Mondial says that the new ones aren't like the old ones and shouldn't fail at all.
    Dude, hopefully you do something for air flow in your rack. [​IMG]
  9. Kal
    Kal Agent
    Jul 27, 2002
    33
    Thanks for the info Kevin!
    "Dude, hopefully you do something for air flow in your rack."
    Yup! It's completely open in the back no problems at all with ventilation. It's actually considerably better then when I used to have the stuff shelved on 'normal' stands since now it's open on all sides except the front.
    Kal
  10. StephenMSmith
    StephenMSmith Stunt Coordinator
    Apr 29, 1999
    85
    I actually managed to break the green LED in my A200x3 when doing a little too aggressive cleaning inside it, but Mondial was nice enough to send me a couple replacements for free. It just slid on to the end of a bent wire. Is this the different design? Why would people need to send their whole unit back for repair?
    Steve
  11. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    I just bought a used 200X3 and now I'm wondering about the "light". Has it been determinded whether or not it's a LED or a neon lamp or an incandescent lamp? BTW, mine is NOT an A200X3 (newer model with cosmetic changes like the big Acurus logo in the front panel cutout).
  12. Kal
    Kal Agent
    Jul 27, 2002
    33
    Hank,
    The newest version of the Acurus amp line can be seen in the photo above - these use LED's (not neon lamps).
    Kal
