David_Rivshin
- Dec 13, 2001
Wasn't sure if this fits better in the HT construction forum or here, so I flipped a coin
This is largely a hypothetical question for now, but I've been considering putting an inexpensive front projector (along the lines of a Panny L300u) in my apartment living room. The design would have a fixed panel style screen attached to the ceiling with hinges so it could be moved out of the way. In the down position it would be infront of the existing TV which has the center speaker placed ontop of it. This would, of course, place the center speaker behind the screen.
So, I would need a screen material which is acoustically transparent, and yet suitable to project an image onto. The only acoustically transparent commercial screen I found is the Da-Lite model, but that would run me in the neighborhood of $600. I'm not willing to spend that much money on a temporary screen for a $1700 projector. In addition I've read that such perforated screens cause moire patterns with fixed pixel projectors, which makes alot of sense.
So here comes the actual question: Does anyone know of a material which is at least largely acoustically transparent, suitable for projecting an image onto and can be had for a reasonable price? I can build the frame, etc, myself if I can find the fabric separately. My receiver is a Sony DA5ES, so I do have a simple 3 band parametric equalizer at my disposal for the center and can correct for small problems.
I know burlap has been said to be acoustically transparent, but I would think that it would produce a very fuzzy image.
The only thing I could think of so far is linen or cotton, perhaps from a sacrificed bed sheet, but I have no idea if it's acoustically transparent enough.
Any thoughts/suggestions? Any other problems I should consider?
Thanks in advance,
-- Dave
Thanks in advance,
-- Dave
