Acoustic Research Repair Help (AR1)
Discussion in 'Archived Threads 2001-2004' started by Chuck Sullivan, Sep 9, 2002.
  1. Chuck Sullivan
    Jul 13, 2000
    18
    I need to replace the subwoofer in my AR1. It's the 15" side firing type with the Sunfire power amp and I'm not sure how to take it out. Any help would be appreciated.
  2. BorisKaganovich
    BorisKaganovich Stunt Coordinator
    Jul 26, 2002
    117
    They should have a 5 year warranty....
  3. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Chuck,
    The AR7's 9's 5's and 1's are all built roughly the same.
    To remove the 15" Sub from your AR1 you need to remove the
    cloth grill. It is a little tricky to get that grill off
    but it is meant to be removeable. You need to push straight
    down on the grill (from the top) and it will bow enough so
    that the tabs will release and you should be able to pull
    it off.
    Once it is off you just need an allen key to remove the
    allen headed wood screws around the sub woofer basket.
    Once it is removed from the enclosure call AR and get a
    Return Authorization if they require one or email them from
    thier web site ( www.acoustic-research.com) they should
    replace the sub no questions asked.
