Acoustic Research HC6 with banana plugs?
Discussion in 'Speakers' started by Javier_A, Jun 18, 2003.
  1. Javier_A
    Javier_A Auditioning
    Dec 10, 2002
    12
    Hi,
    I've just ordered the Acoustic Research HC6 speaker system. In the meantime, I'd like to buy some banana plugs for the speaker wire. However, I read in a couple of reviews that the speakers don't take banana plugs, yet a different review said they did. Can HC6 owners please let me know what connectors fit in the speakers? I'd prefer banana plugs, but if they don't work, will spades or pins fit?
    Thanks!
  2. terence
    terence Supporting Actor
    Nov 8, 2002
    985
  3. Geoff L
    Geoff L Screenwriter
    Dec 9, 2000
    1,693
    If you missed it or did not read it:
    Terence~ *linked review*
    They do have metal binding post,
    but ~{DO NOT}~ allow use of banana plugs according to the review.
    Don't let that sway you from the AR-HC6 system, very nice set up for the money. Look far more expensive than their current going price with their black piano lacquer, also have seen excellent reviews.
    Regards
    Geoff
  4. Kevin McCurdy
    Kevin McCurdy Stunt Coordinator
    Oct 13, 2000
    183
    Pins or spades are the best option for these speakers as Geoff L pointed out they do not accept banana plugs. I ended up just inserting bare 12 guage wire into the posts and tightening the binding post cap.
  5. Javier_A
    Dec 10, 2002
    12
    Thanks for the replies. I had also read the same review that terence pointed out, but then there is another review here: http://www.audiorevolution.com/equip...cresearchhc6/. Take a look at the third paragraph:
    "The speaker connections will allow bare wire, one-quarter-inch spade lugs, or banana jack connections..."
    A little condradicting to say the least. Have you guys actually tried to connect banana plugs? I would prefer them for the convenience, if possible.
    For spades, do you think these would fit for example: http://www.partsexpress.com/pe/showd..._ID=2475&DID=7
    Thanks!
  6. Geoff L
    Dec 9, 2000
    1,693
    Those are very nice spades and quite heavy duty. Well worth the price and I have used them myself before.
    Their notched for 3 different post sizes. But some 5-way binding post shafts are to thick for them to slide on to! If you need the 3 different widths between the fork let me know.
    Will they work:
    Can't say as to if they will "fit the AR's post or not"!.
    You might have to wait till they arrive, or hopefully someone will post that actually owns them and can tell you "what will definitely fit"..
    Regards
    Geoff
  7. Jack Briggs
    Jun 3, 1999
    16,738
    129
    I simply connected 14-gauge wire directly to the binding posts on my HC6 setup in the bedroom system.
  8. Kevin McCurdy
    Oct 13, 2000
    183
    The spades from PartsExpress #091-315 will not fit. I tried them, the posts on the HC6's were too thick. The set of HC6's I received did not accept banana plugs.
  9. MatthewCopp
    MatthewCopp Auditioning
    Jun 19, 2003
    The Mains, Center and Satellites have gold plated binding posts that do not accept banana plugs. The subwoofer for some odd reason, does have plastic binding posts that accept banana plugs. That's why there is some confusion.
    This is a nice system and you should enjoy it. Hopefully Audiovox won't screw up the whole company.
  10. Javier_A
    Dec 10, 2002
    12
    Kevin, thanks for confirming that those spades from PartsExpress will not fit, it's too bad. Do you know of any spades that will fit those posts? It sounds like the gap would have to be a bit wider. What about the pins here instead: http://accessories4less.com/aless4/C...2D405&cc=&tpc= for example? I really would like to use some sort of connector because at least the front speakers will be moved together with the receiver every once in a while, and I'm afraid that the bare wire might wear down more quickly.
    I'm really looking forward to getting the speakers!
  11. Kevin McCurdy
    Oct 13, 2000
    183
    Javier_A,
    I didn't try anything else, so I'm not sure which connectors would fit. I ended up inserting bare wire into the binding posts.
  12. JackS
    JackS Supporting Actor
    Jan 17, 2002
    634
    Javier- An excellent connection can be made with bare wire. Why not wait until you get your speakers then you'll know exactly what you need. You can run down to your local Radio Shack and purchase just about any connector that's available. I'd suggest pins if possible if bananas can't be used. This is for safty sake as spades really aren't much safer than bare wire. I've already had one bad experience with spades when a speaker was knocked over and the wires were jerked into a short which could have blown my amp. If spades must be used, design a barrier between the posts. I used little self adhesive rubber feet.
