Kincade
- Dec 6, 2002
I've been looking to upgrade my KP53HS30 for about 3 months. I've now narrowed it down to the Mitsubishi 55413 and the Pioneer SD-643HD5. I'll be buying one in the next 24 hours.
They are both within $200 of each other, but the Pioneer won't come with an extended warranty - just a return warranty. Mitsu will come with a 5 year warranty. Pioneer I have to pick up, Mitsu is delivered.
I want the best stretch mode possible for the SAF (which I think goes to the Pioneer from what i've read) - this is extremely important, as she doesn't want to get rid of the 4x3 for this very reason; Best image using DVD (about equal I read); and best size for my room.
I've read all the calculators on the net, and I still can't decide which is the correct size. Main viewing couch is 112" away from the TV,, with the other couch running perpendicular to that, from 112" forward towards the TV and to the side. Most calculators say that the 64" would be better, but wouldn't this still overwhelm the room?
Thanks in advance for any advice you can offer! This is a big purchase for us, and I hope I don't regret which I go
