Accoustic help in my theater room
Discussion in 'Speakers & Subwoofers' started by Blaine_M, Aug 29, 2004.
Thread Status:
Not open for further replies.
  1. Blaine_M
    Blaine_M Second Unit
    Mar 11, 2004
    400
    I posted this in the DIY forum, thought I'd try here as well. I'm trying to make accoustic improvements to my room. My wife won't let me put accoustic pannels or anything like that on the walls. She will be adding curtains to the room soon. I was thinking about building my own 'diffusor' using fiberglass insulation. What are the accoustic properties of fiberglass insulation. I was thinking about doing some type of pillar type treatments, only mine would be square. I was going to fill them with the fiberglass, then on the back of them attach accoustic foam where it won't be visible. Placement of these will be in the corners behind my speakers. What do you think, will this work?
  2. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    3
    5,110
Thread Status:
