Accessing shares: 1 PC is fine other not sharing
Discussion in 'Archived Threads 2001-2004' started by Greg Haynes, Mar 31, 2002.
  1. Greg Haynes
    Greg Haynes Supporting Actor
    Oct 22, 1998
    577
    I just finished setting up my peer-to-peer network and I am having problems accessing shares on new machine. Right now the new machine is using winxp pro and the old machine has w2k pro. I am using a linksys 4port router and both machines have access to the internet and we both can play head-to-head games fine. I can see the shares in network places but can't access them. I can access shares on my old machine, but the old machine can't pull anything off the new one. I keep the getting the error:
    Not enough server storage is available to process this command.
    Does anyone know how to fix this?
    New Machine:
    P4 1.6A
    ASUS P4S333
    512mb PC2700
    Old Machine
    PIII 500mhz
    Intel Board
    256 pc100
  2. Roland_Sjouw
    Roland_Sjouw Extra
    Oct 16, 2000
    20
    Maybe this will help, it is a message from Nt 3.1 but the same as youre's...
    Ps. You can almost always find the answer on Microsoft Technet :
    www.microsoft.com/technet
    http://support.microsoft.com/default.../>
    US;Q166840
    Err Msg: Not Enough Storage to Complete Operation (Q166840)
    The information in this article applies to:
    Microsoft Windows NT Server version 4.0
    Microsoft Windows NT Workstation version 4.0
    Microsoft Windows 2000 , Professional
    Microsoft Windows 2000 , Server
    Microsoft Windows 2000 , Advanced Server
    SYMPTOMS
    When you try to open the Printers folder, you may receive the following error message:
    There is not enough storage to complete this operation
    CAUSE
    The size of the registry has exceeded the maximum size set in the virtual memory settings.
    RESOLUTION
    Increase the maximum registry size. To do so, follow these steps:
    Click Start , click Control Panel , double-click System .
    Click the Performance tab, and then click Change (In Windows 2000, click the Advanced tab, click Performance Options , and then Change ).
    Type a new, larger value in the Maximum Registry Size box, and then click OK .
    Close Control Panel and then restart the computer.
    MORE INFORMATION
    The registry increases in size as you install programs and use the computer. It may be necessary to increase the size of the registry periodically, depending on how and how much you use your computer.
  3. Greg Haynes
    Oct 22, 1998
    577
    No Dice, I tried the registry thing and nothing. I only could change the registry size on my w2k machine. I don't know how to change it on XP. There is know option that allows me too. Another thing I just found out is when I try to run Norton DiskDoctor I am getting a message stating the operating system has exclusive access to the c:. This message starting coming up when I tried to rename my c: drive as c$. Is there anything I can do fix this? How do I unlock my c: drive now? Even if I turn off sharing it stills comes up saying the operating system is the only allowed to access the c:.
