Christ Reynolds
- May 6, 2002
- CJ
i have started the process of capturing the entire series of twin peaks from the vhs tapes i have. i started to capture the pilot episode, and i ended up with dropped frames. i figured i would capture uncompressed, and then use tmpegenc to encode the avi to the bitrate i needed. maybe it wasnt the best reasoning, but i wanted to have the video as close to native as possible. anyway, during the capture (352 x 480) i dropped 60 frames. should i worry about this? i have deleted the file already, but i wanted to know if i should keep it next time if it only drops around the same amount of frames. thanks.
CJ
CJ
