I've decided to go with front projection for my new theater room. My local dealer has recommended the Plus Piano Avanti HE-3200. The price is right at $2999.
Are there other projectors I should consider in the $3,000 range? Usage will be 50% television, 30% DVD, and 20% HDTV. I will have total control of the light in the room.
Thanks in advance.
Thanks in advance.
