about soundblaster audigy platinum
Discussion in 'Archived Threads 2001-2004' started by felix_suwarno, Oct 23, 2002.
  1. felix_suwarno
    felix_suwarno Screenwriter
    Dec 2, 2001
    1,523
    can i plug in my xbox to the audigy and get 5.1 sound out of my pc speakers?
  2. John Parris
    John Parris Stunt Coordinator
    Aug 10, 2002
    235
    Yes... run the optical from your xbox to the optical input on the audigy drive
  3. felix_suwarno
    Dec 2, 2001
    1,523
    thanks, but i still have another question.
    can i buy audigy2 then add the 5 1/4 inch drive later? i dont need it at this point.
  4. Chris Svencer
    Chris Svencer Stunt Coordinator
    Mar 4, 2002
    78
    Similar question...Can I buy the audigy 1 now and buy the 5.25" drive later, or do i have to buy it all together?
    -Svence
  5. TyC
    TyC Stunt Coordinator
    Nov 4, 2001
    184
    Yes, the Audigy 1 drive can be purchased separately. As far as the Audigy 2 drive, it is not available for sale on Creative's website, but I expect that to change soon.
  6. John Parris
    Aug 10, 2002
    235
    I dont know that the Audigy2 drive is worlds apart from the original... is it different at all? I think all the actual processing is done on the board, not in the 5 1/4 part, so I don't think they had to change anything... would be interesting to see if they are interchangible.
  7. TyC
    Nov 4, 2001
    184
    From Creative's Knowledge Base:
