About HT Receivers and Creative's EAX
Discussion in 'Archived Threads 2001-2004' started by Sandra B., Aug 20, 2002.
  1. Sandra B.
    Sandra B. Extra
    Aug 19, 2002
    24
    Hi all!
    Well, i have a question that mixes PC gaming and Home Theater.
    You know that with Dolby Pro-Logic II and NEO:6 modes, you
    can make surround audio with 5 or 6 channel from a stereo or
    surround source. But, ¿if i connect the audio outputs of the
    Sound Blaster Audigy to the receiver, will it process the
    multichannel EAX sound mode that most games use with Pro-Logic II or NEO:6 and achieve good results?.
    That i want, as you supposed, is to use a Home Theater system with my pc for gaming. ¿Will this work well? No one in my local Home Theater stores give me a good answer.
    Thanks! [​IMG]
  2. Jason Wilcox
    Jason Wilcox Supporting Actor
    Feb 21, 2002
    652
    your best bet would be to use the 5.1 analog inputs.
