Sandra B.
Grip
- Aug 19, 2002
Hi all!
Well, i have a question that mixes PC gaming and Home Theater.
You know that with Dolby Pro-Logic II and NEO:6 modes, you
can make surround audio with 5 or 6 channel from a stereo or
surround source. But, ¿if i connect the audio outputs of the
Sound Blaster Audigy to the receiver, will it process the
multichannel EAX sound mode that most games use with Pro-Logic II or NEO:6 and achieve good results?.
That i want, as you supposed, is to use a Home Theater system with my pc for gaming. ¿Will this work well? No one in my local Home Theater stores give me a good answer.
Thanks!
Thanks!
