willemBER
- Sep 27, 2003
room is 16x12x9. I will be projecting on one of the 12' walls. Seating will be about 13-14' from that wall. If the mains beside the screen are 1' from the side walls they would be 10 feet apart. Will that be OK considering the distance from each speaker to the seating area is more than 14'?
Also, I wanted to wall mount the surrounds on the side wall about 2' behind the seats and about 6' high, but the way the door opens into the room that is not possible. Would it be OK to mount them on the rear wall above the door? This would make them another 1 1/2' back and about 2' higher.
Finally, the center channel. Above or below... Below would be so much easier. Eventually I will have an acoustically neutral screen, but that is who knows how many years off.
This room will be dedicated HT for movies only with Onyx Rocket ELT speakers.
Thanks for help in advance
-W
-W
