? about 1080i
Discussion in 'Displays' started by Harold Southard, Feb 9, 2004.
  1. Harold Southard
    Harold Southard Stunt Coordinator
    Dec 31, 2003
    138
    I am watching "Fear Factor" right now in HD. The signal is 1080i, but I have black bars on the sides. As you may know in 1080i mode you can not change the aspect. Is this because the broadcast station is sending a 4 x 3 signal? My kids and I watched the Lion King sunday (on ABC I think). It filled the screen, but the spots where the host spoke about the dvd that comes out tuesday and the commercials were not. Also 720p does the same thing. By the way my tv is a Panasonic 53wxd63 RPTV. This may be a silly question, but this is my first HDTV. The picture is stunning. The built in tunner does a great job, I am picking up all my locals on non-amped rabbit ears from about 70 miles away!
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    If the HDTV broadcaster is sending 4:3 out their HDTV feed, this is normal.
  3. Harold Southard
    Dec 31, 2003
    138
    That's what I thought. Thanks for the reply.
  4. Jeff Gatie
    Jeff Gatie Lead Actor
    Aug 19, 2002
    6,531
    15
    Commercials and shows that are non-HD (4:3) are upscaled to HD and broadcast with bars on the side or (in the case of ESPN-HD) stretched. This is normal until more HD content is available. The superbowl had a couple HD commercials, so they are coming, until then we will have the bars (sometimes bars on all sides due to non-HD letterbox commercials).
  5. Anthony_J
    Anthony_J Stunt Coordinator
    Jul 31, 2001
    242
    HD channels always broadcast in a 16:9 format. With 4:3 material, they'll add the bars to the sides to fill up the aspect ratio. Your TV doesn't know the difference. As far as it's concerned, you're getting a 16:9 picture.
    ESPND is the only station I've seen that doesn't use the bars, they'll actually stretch the 4:3 material as part of the broadcast.
  6. Harold Southard
    Dec 31, 2003
    138
    Thanks. I suspected as much, but was unsure.
