Abit Nf7-S sound setup
Discussion in 'Computers' started by Jassen M. West, Jan 7, 2004.
  1. Jassen M. West
    Jassen M. West Supporting Actor
    Jun 22, 2000
    526
    The Abit motherboard has output for 5.1 surround sound on the back. The subwoofer output is the same as the center channel output. I connect my SVS to the sub/center jack and my left/right speakers to the jack that outputs the front L/R speaker signal. The speakers work, the sub doesn't. Does anyone have any ideas?
    thanks,
    jay
  2. WayneO
    WayneO Supporting Actor
    Nov 10, 2003
    625
    Is analog out checked? Maybe go through the speaker wizard if you haven't already.
  3. Frank_Lee
    Frank_Lee Agent
    Apr 4, 2001
    43
    If you've installed the Nforce audio drivers, you should see an Nvidia logo in your system tray (bottom right corner). Double click, and it'll bring up the Nforce control panel. One of the tabs (I forgot which) should have a drop down menu for the number of speakers in your setup. Since you want 5.1, you'll want the 6 speaker setup. Hope that helps. I've got the same board and I really like it.
  4. MorganT
    MorganT Auditioning
    Dec 1, 2003
    13
    I had a similar problem with my SB Live! 5.1
    You need to enable your DVD software to pass thru the SPDIF.
