A7N8X deluxe
Discussion in 'Computers' started by KeithY, Feb 1, 2004.
  1. KeithY
    KeithY Stunt Coordinator
    Apr 23, 2003
    126
    using two 512megs pc2700 under winXP
    With the CPU external frequency set a 133MHz everything runs fine, if I bump it up
    to 166 or 200 the system becomes unstable. The machine keep sending out errors
    and sponatiously restarts.
    Any ideas what could be the problem?
  2. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    Possibly the RAM. I had a similar issue with my standard A7N8X (both of them) because I was using Crucial RAM. Change to Samsung and problems disappeared.
    PC2700 should run at 166.
  3. Max Leung
    Max Leung Producer
    Sep 6, 2000
    4,611
    I can't get my A7N8X Deluxe rev 1.03 to work with my PC2700 Samsung RAM (2x512mb sticks) @ 166. Clocking them to 150 Mhz works though. However, I have had those DIMMS for 2 years now, so I blamed the RAM.
    I did upgrade the BIOS though...maybe I can try 166MHz again...
