P
Patrick Donahue
Greetings all,
We have had many a debate regarding physical vs. digital media on this site. Myself, I have gone back and forth, seeing advantages to both. Today I have finally picked a side...
Viva La Blu-Ray
If you may have missed reading about it on other forums, many users had a large amount of movies turn up missing from Vudu. I personally had around 200 titles vanish. To be clear, these are movies that are still available on Vudu's site, and are all still in your UV locker, but as far as Vudu is concerned, you no longer own them. Vudu was notified on their forums, and they said they were working with UV to figure it out. After 5 days, they just posted this response:
"It appears that UV finally resolved their issue with large UV lockers and having them sync up with UV providers. Our engineers have investigated the issue and all looks fine from our end. So it seems that many large UV lockers contain rights that do not transfer over to Vudu for various reasons. For example, if you show 1000 movie rights in UV, that does not necessarily mean you'll have 1000 movies on Vudu. Many user UV accounts contain duplicate rights for the same movie, invalid ALIDs, and/or international ALIDs. We do not support ALIDs that are meant for international use, therefore those titles will not import into Vudu. So if you have a particular movie in your UV locker that will not import into Vudu, then it most likely has an ALID issue. Since the ALID is created by the provider with whom you acquired the movie with, only they can update the ALID to allow it to import into Vudu. You would need to contact that providers support channel and have them resolve the ALID issue for you."
I just offer this nonsense to anyone who might still be deciding if they feel safe going "entirely digital" or not.
I no longer do.
Viva La Blu-Ray
I no longer do.
