wired7124
- Apr 28, 2008
- Brad
I have a new home and am looking for some ideas on routing my A/V wires.
All of the components such as Reciever, DVD player, SUB, Satellite etc will be in a closet adjacent to the same room. The idea I am after is to hide all the components with the exception of the TV and speakers. I plan on using an RF remote for control of the components, and will wire a panel as needed in the closet for connectivity. When I desire the use of the SUB, I will just open the closet door.
The TV is on a wall about 20ft wide, 10ft ceilings, and hardwood floors. There is an upsatirs so access for wiring there is out. This same wall is a bearing wall sitting on a foundation, so wiring under it presents an issue. I would really like to run the wires under the floor as access is easy. Oh, this same wall is also shared with my garage, which is also already finished, but access from the backside is there if needed.
Is there a nice clean way to do this? or am I stuck using some kind of ugly plastic miolding on the exterior of the walls?
If I have to notch a hole in the hardwood on that wall, I can, as long as it is cosmetically coverd up well afterwards. I really havent the opportunity to do this kind of work, so I am open for any creative ideas.
