a sonosub from a comercial ported box sub?
Discussion in 'Archived Threads 2001-2004' started by Manuel Delaflor, Feb 19, 2002.
  1. Manuel Delaflor
    Manuel Delaflor Supporting Actor
    May 25, 2001
    657
    I have a Kenwood subwoofer.
    Now, I know the dimensions of the box, the lenght of the port, that the driver is 8 inch, the amplifier put 100w RMS and that it appears to be tuned at around 35Hz or 40Hz (by the shape of the graph response).
    I know those are not at all the parameters to build a sonosub, but I wonder if you experienced guys can help me on this.
    I think that it could be possible to make an audible sonosub from all this. Worth it? is there any possibilites to have a lower extension?
    For example, what happens if I just give the drive and the port twice the volume?
  2. IMO, it wouldn't be worth the effort to make a sonosub from that driver let alone not knowing the T/S. A well built sonosub and well built box will have the same performance.
  3. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    To put it concisely, don't bother. There's no magic in merely using a sonotube.
  4. Kyle Richardson
    Kyle Richardson Screenwriter
    Jan 1, 1998
    1,073
    Exactly as the others have stated. You will not gain anything by making your Kenwood into a sonotube.
    Kyle Richardson
    Acoustic Visions
  5. Manuel Delaflor
    May 25, 2001
    657
    Wow, I think I understand much less about making a sub than I thought!
    Do a driver and its enclosure are a kind of symbiotic thing? I mean, you can't use a driver in a cabinet not designed around it? (or have good results from doing it)?
    I really thought that changing the working volume should bring some positive changes...
  6. Jack Gilvey
    Mar 13, 1999
    4,948
    I thought I remembered this subject. Nothing has changed.
  7. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
  8. Manuel Delaflor
    May 25, 2001
    657
    you got me Jack...
