A small technical question about laserdiscs (1 Viewer)
Jon Robertson
Was it possible to put both CAV and CLV video footage on the same side of a laserdisc? If, for example, one had the tail end of a film in CAV, then wished to put some supplemental footage in CLV so as not to extend onto another disc.
Davin D
I don't know if it's possible or not. I do know that I have many laserdiscs and have never seen it. I would doubt it as the player would have to change speed (or type of speed) in the middle of a side. I would think that would be difficult to do.
Matt Stone
Matt Stone
I can't be 100% sure, but I don't believe it's possible.
PS, Nice Shaun of the Dead sig, Mike :)
Gary Seven
Grand Poo Pah
Lake Worth, Florida
Gaston
No.
CAV puts the same amount of info on all tracks. CLV puts information in the amount that will fit on that track, thus, the amount of data differs from track to track. Being that the case, I don't see how they could have mastered a laserdisc with two different technologies on the same side.
Jon Robertson
Many thanks for your help, gents. I didn't think it was possible, but I wanted to make sure by those who knew more about the subject than I. :)
ChristopherDAC
AE5VI
From reading documentation, I think this was done on an early series of test discs, but as far as I know never on any commercial release. While physically possible, the technical difficulties [including the fact that CLV frames are encoded with a different set of subcodes than CAV frames] and lack of any particular motivation to do it would make it unlikely in the extreme to be implemented, and it was not written into the mastering standard. It is virtually certain you will never encounter such a disc, no matter how many LDs you go through.
iLogics
