ReggieW
- Mar 6, 2001
My JVC RX-778VBK operation manual reads:
IMPORTANT:
THE SAMPLING RATE CONVERTER BUILT IN THIS UNIT CORRESPONDS ONLY TO 32kHz, 44.1kHz, and 48kHz. IF THE SIGNALS OF A DIFFERENT SAMPLING FREQUENCY COME INTO THIS UNIT, NOISE MAY OCCUR.
Hence, this is exactly what I get from my JBL N-24 (great speakers btw!) rear surrounds during DVD-A playback. I guess I was wondering if there are any receivers capable of properly processing the high-sampling rate (92kHz-192kHz) of DVD-A? I was also told that all of your speakers should be full-range to truly get the full DVD-A effect. What do they mean by this? I have a JVC 721BK, and was hoping to fully take advantage of all DVD-A has to offer. However, if current receivers can't handle the high sample rate, then this won't be likely (enjoying DVD-A to it's full potential) until they begin making receivers/amps to handle the high sample rate. I was Just curious if any of you had thoughts, insights, or recommendations.
Reg
IMPORTANT:
Reg
