Cagri
- Dec 18, 2002
The AVIA disc has quite a few "tests" that (I do not believe) are available with a simple test tone generated by your receiver. For example, it will check the phase on every speaker, in detail, and provide you with detailed instructions on how to correct this, if any of them come up "out of phase."Does S&V disc have these test tones as well for checking the phase? Thx..
