A Question on THD... (1 Viewer)
NickSP
When using a receiver as a prepro, how does it contribute to the THD? Is the receiver's THD a factor at all or is it the amplifier's THD that comes into play?
Fredrik E
Since you are using the "line out" outputs of the receiver, the THD from the receiver is very, very low, near zero, so it is mainly the THD from the power amplifier's output that comes into play.
linda19798888
