Chris_harpua
- Feb 24, 2004
Im looking into buying one of these, anyone have any advice on which one to get. I cant spend more than $350, preferably under $300. I dont care about the sound from the set, im hooking it up to my Onkyo hts760, I just want one with a nice picture to replace my old 20" Panasonic that ive had for the past 7 years. I dont have room for anything bigger than a 27" though and Ive heard that Toshiba has some of the best pictures. Id like a variety of a/v connections and audio out. Dont care if its flat screen or not because glare isnt a problem for me. Thanks.
One more quick question, what is the difference between the 27A33 and the 27A43?
