A question about dvd burner drives
Discussion in 'Playback Devices' started by Xenia Stathakopoulou, Feb 8, 2004.
  1. Xenia Stathakopoulou
    Xenia Stathakopoulou Cinematographer
    Apr 25, 2003
    2,417
    If i replace my cd/rw drive on my pc, with a dvd/r drive, will it do all this ? Be able to backup my existing dvds, cds, be able to watch dvds on my pc,plus,will i be able to play my pc games too ?[​IMG]
  2. Cahyo Wicaksono
    Cahyo Wicaksono Stunt Coordinator
    Oct 9, 2003
    69
    1. It depends on your PC configuration
    2. I think this is the wrong forum to post this thread.
  3. Xenia Stathakopoulou
    Apr 25, 2003
    2,417
    Well, if it helps at all my pc is windows xp compatible,and it says usb on the tower,and has lots of space.Thanks.
  4. Xenia Stathakopoulou
    Apr 25, 2003
    2,417
    By the way, mods feel free to move this .
  5. Cahyo Wicaksono
    Oct 9, 2003
    69
    That's still doesn't help at all.
    What processor speed, size of RAM, type of video-card, size and speed HDD (and amount of HDD space left)?
  6. Xenia Stathakopoulou
    Apr 25, 2003
    2,417
    512 mb ram,intel celeron cpu,2.42 ghz,4o gb hard drive,with 22.8 left.[​IMG] THANKS.Not sure on the video card, but it can play the most demanding of games.
  7. Cahyo Wicaksono
    Oct 9, 2003
    69
    the long awaited answer is:
    "yes"
    How to backup the DVD? I'll send you a link. We're not allowed to discuss it here.
  8. Xenia Stathakopoulou
    Apr 25, 2003
    2,417
    Thanks, no need for the link, though i appreciate it.Also, will i need a specific model to get all that i asked in my original post , or do all of todays dvd burners do all that?
  9. Xenia Stathakopoulou
    Apr 25, 2003
    2,417
    On second thought send the link after all, Thanks Cahyo !
  10. Don_Berg
    Don_Berg Supporting Actor
    May 30, 2003
    931
    Most likely yes with the appropriate software.
  11. Garrett Lundy
    Garrett Lundy Producer
    Mar 5, 2002
    3,764
    You may need some additional software too.
