a question about distance to rear surrounds...
Discussion in 'Speakers' started by Rob Michaw, Apr 16, 2005.
  1. Rob Michaw
    Rob Michaw Stunt Coordinator
    May 2, 2000
    132
    Searched but couldn't quite find an answer. I have my surrounds essentially in a null posisiton (beside me...perhaps back 6 inches or so). Unfortunately, with my room placement, I can't get a fantastic front stereo image where my seating is. If I move my seating forward, my soundstage improves greatly. My surrounds are unfortunately tethered pretty solidly where they are, so they will end up being a couple of feet behind my seated position.
    Generally speaking, how far forward can one move from their rears to keep them in "optimal" position? Obviously it is a personal preference to an extent, but I am just looking for other's experience before I start moving everything around and recalibrating.
    Thanks.
  2. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
  3. Rob Michaw
    May 2, 2000
    132
    That helps visually...but how do I translate my environment into degrees from sweetspot?
  4. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    what are you working with? 5.1 6.1 or 7.1??
  5. Rob Michaw
    May 2, 2000
    132
  6. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    I believe the general consensus around here is (for the sides)anywhere from directly to the side up to a foot behind and about 1-2 feet above ear level. Of course it all depends on your room set up. This is all if you have direct radiating speakers (monopole).
    I have limited space so I have to do directly to the sides.
  7. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    Or get yourself a GIANT protractor! [​IMG]
