A question about buildings.
Discussion in 'After Hours Lounge (Off Topic)' started by Dome Vongvises, Jun 1, 2003.
  1. Dome Vongvises
    Dome Vongvises Lead Actor
    May 13, 2001
    8,172
    What's that enclosed space called that exists between the outside and inside of a building? Almost every building I've ever come across has one.
    When you past the first set of doors, you're usually inside an enclosed space. Usually this space has mall advertisements or a garbage can with an ashtray. When you walk past the second set of doors, you'll find yourself in the main inside of the building. Is there an architectural name for this?
  2. Jeff_Krueger
    Jeff_Krueger Stunt Coordinator
    Aug 5, 2000
    122
    I believe it would be called a vestibule see 2a.
  3. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    Dome, it snows where you live, doesn't it?
    Glenn
  4. Jay H
    Jay H Producer
    Mar 22, 1999
    5,654
    32
    Pittsfield, MA
    Jay
    ..or perhaps a foyer ??
    Calling all architects...
    Jay
  5. Dome Vongvises
    May 13, 2001
    8,172
    Thanks Jeff.
  6. Dome Vongvises
    May 13, 2001
    8,172
    Oh, I didn't see your post Jay. I've always wondered what the difference was.
  7. Jeff_Krueger
    Aug 5, 2000
    122
    no problem Dome,
    I would guess that foyer would be more appropriate for a home. Also a foyer is a space that is typically open to the rest of the dwelling, or acts like a room unto itself. Whereas a vestibule would specify a small space that is enclosed by two sets of doors. Here in MI most all public buildings have a vestibule, to keep loss of heat to a minimum in the winter months, I'm sure it serves a purpose for the summer months as well with air conditioning but it helps to keep from getting the cold blast of air everytime the door is opened during the winter.
    Note I'm not an architect, though I do play one on the HTF[​IMG]
    Off topic, though I did want to be an architect at one time, but oh well, now I work in IT and am majoring in German go figure[​IMG] [​IMG]
  8. Shane Bos
    Shane Bos Second Unit
    Jun 15, 2002
    256
    Jeff is correct on this one.
  9. DaveF
    DaveF Moderator
    Mar 4, 2001
    17,973
    1,543
    One Loudoun, Ashburn, VA
    David Fischer
    It could be an airlock (If your mall was in space [​IMG] )
  10. Lee L
    Lee L Supporting Actor
    Oct 26, 2000
    868
    Actually, vestibules are sometimes called airlocks even though they really just slow air movement down 95%.
