Dustin B
- Mar 10, 2001
In another thread on this forum I was explaining why you should crank the crossover on a sub when you are using the crossover in the reciever.
The sub in question in a Paradigm PDR10. The suggestion is that setting the PDR10's crossover (which I think is 2nd order) to 100hz and also using the receivers 80hz crossover results in a flatter frequency response than cranking the PDR10's crossover and just using the receivers 80hz one. Here is part of the post from the other thread.
20hz through 90hz, where it starts to falloff.
I know highpass rumble filters on subs can cause different levels of boost above the filters corner freqeuncy (is that the right term?). But can a low pass filter cause a decrease in output below its corner frequency like this quote is suggesting. Ignoring the cascading crossover problem for now.
Any thoughts?
