- Feb 8, 1999
- Robert Harris
If one sums the running time of these Blindness and {Proof}, the number is 222 minutes -- the length of the original uncut Lawrence of Arabia, or alternatively Gone with the Wind. Plus special features.
This new disc, one of a series of double bills from Echo Bridge is now up on Amazon at $19.99, which is quite close to $20.
The current Blu-ray of {Proof} at $7.99 plus the Blu-ray of Blindness at $12.29 works out to $20.28.
Which means that if a consumer only wishes to own one, they're better off buying singly, and if one keeps their discs in their library in alpha order, for the additional 29 cents, the single disc is also the better way to go.
But math aside, I sampled this disc, and having heard of quality problems with Echo Bridge discs in the past, was alert to potential shortcuts.
I really didn't find any. A bit of odd background grain, but nothing untoward, certainly not noticeable if one is sitting the proper distance from the screen.
These are to very interesting and worthwhile films -- although I'm not sure why they make a double bill -- and they look and sound just fine.
I'm confused by the price, and the re-issue, but have no real problems with quality.
If there have been major quality problems with EB in the past, it appears that they turned a corner, or there may have been no problems with these titles. As a BD-50, this may simply be both layers of the original BD-25s, with a new menu.
While I would probably consult with my financial advisors toward purchasing the single titles for the additional investment, if one is desirous of owning both, this works out just fine, and saves both plastic and shelf space.
Image - 4
Audio - 5
Recommended.
RAH
Image - 4
Audio - 5
Recommended.
RAH
