- Feb 8, 1999
- Robert Harris
I have a dear friend, who when she has something of importance to say, always seems to begin the discussion with the word, "so..."
So...
I popped Ang Lee's newest offering from Columbia (Tri-Star actually) into my Panasonic 4k player, after which I'd checked the processor to see that it was set to that player, which was also after I turned on the Sony 665.
I've been told that if you want everything to play nicely together in 4k, start with the panel or projector, and work backwards from there.
The cause for my concern is that Billy Lynn is the first 4k UHD Blu-ray that runs at 60 fps.
When all of this began, back around 1894, 16 frames per second was considered fast.
It worked, and even when speed rose to the heights of 20 fps, our films were still known as "flickers," because that's what they did.
Once sound arrived, 24fps became the standard, along with an aspect ratio of 1.37.
That took a bump in October of 1955, when Oklahoma! arrived, running at 30fps, and alleviating the problem of picket-fencing, normally seen during tracking moves.
30fps, as you can see from the Oklahoma! Blu-ray, has a magisterial quality about it. You know you're watching something not only different, but special.
It's taken 61 years, and numerous experiments, for Ang Lee, with the extraordinary John Toll behind the camera, to up that ante, creating something that's almost other-worldly.
So...
An image hit the screen, along with a notification that I was running 4k / 24 fps. Fortunately, that was for the warning screens.
When the logos arrived, a new notification told me I was truly running at 60 fps, and one look at the Tri-Star logo, confirmed the fact.
I've viewed the first ten minutes or so of the film, and have found that I'll need to turn down sharpness a couple of points, but beyond that, I felt the need to report what I'm seeing -- and hearing via Dolby Atmos.
My advice is simple.
If you have 4k, along with a panel or projector that has the ability to run 60fps, run, do not walk to your closest purveyor of cinema software, or hit Amazon (or your web seller or choice) immediately...
And get a copy of this ground-breaking disc, which will arrive next Tuesday, the 14th.
Image - 5*
Audio - 5 (Dolby Atmos)
Pass / Fail - Pass
Very Highly Recommended
Did I use the word "ground-breaking?"
RAH
So...
So...
Image - 5*
Pass / Fail - Pass
RAH
