A few questions about my subwoofer
Discussion in 'Speakers & Subwoofers' started by Vaughan Odendaal, Jan 27, 2006.
  1. Vaughan Odendaal
    Vaughan Odendaal Second Unit
    Aug 4, 2003
    403
    Hi guys,
    I just would like to know a few things. I have an SVS PB10 subwoofer and I believe the tuning frequency is approximately 17.5hz according to several people who I have conversed with.
    How do you calculate this tuning frequency ? I am very interested to know. Thanks.
    --Sincerely,
  2. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    The T/S parameters of the driver, the volume of the box, and the length of the port contribute to the final tuning.
    Download WinISD and play with it for a while.
  3. Vaughan Odendaal
    Aug 4, 2003
    403
    Do you or does anyone have the specs (port length, volume of box, etc ) on the PB10 so that I can understand how the tuning frequency got to 17.5 hz ?
    --Sincerely,
  4. ColinM
    Dec 9, 2001
    2,050
    You have one, right? And a measuring tape?
    If you do, you can measure the box dims and the port length. You can also measure the surface area of the driver. With that data, you should be able to extrapolate some TS information in WinISD.
  5. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    Tuning/Fb is determined by length and diameter of vent and the volume of the box and is independent of the driver's specs. Flaring of the port can change Fb a bit.
    An easy way to determine Fb is to run some low level test frequencies ( at identifiable 1 Hz increments) through the sub while feeling the motion of the driver. The frequency at which the driver moves the least is your Fb, as that's where the port's damping effect is strongest.
  6. Edward J M
    Edward J M Cinematographer
    Sep 22, 2002
    2,031
    I emailed him the close mic woofer sweep of the PB10-ISD. Fb is 17.31 Hz using 1/24 octave sweep resolution.
    I also gave him a few links to Audioholics articles which deal with calculating Fb.
    http://www.audioholics.com/productre...00reviewp4.php
    http://www.audioholics.com/techtips/...orabsorber.php
    He was also interested in how a larger enclosure volume helps with efficiency at low frequencies, so I sent him a primer on Hoffman's Iron Law. This explains why the PB10-ISD has such high output at 20 Hz with only 300 watt amp and virtually no EQ compensation; the enclosure is "right-sized". [​IMG]
  7. Vaughan Odendaal
    Aug 4, 2003
    403
    I read through Hoffmans Law. It gives me answers but it doesn't explain them for me. I still don't know why bigger enclosures give deeper bass.
    I would like to understand the "how" or "why" behind these answers.
    --Sincerely,
  8. Vaughan Odendaal
    Aug 4, 2003
    403
    Does it have to do with the compliance of air in the enclosure ? Can someone explain this for me please ?
    --Sincerely,
  9. Jack Gilvey
    Mar 13, 1999
    4,948
    A larger box is more efficient as the air is less restrictive to the woofer's movement, so there's more deep bass for a given input power. One can achieve a desired frequency reponse in many sizes of enclosure, but a smaller Vb will take more power.
    A large box is a very good design decision from a subwoofer performance standpoint. If a designer accepts a "large" box, like the PB10's, then he doesn't need to jump through very expensive hoops to acheive a performance goal.
    If you really want to see the relationship, download WinISD Pro and play with it.
    http://www.linearteam.dk/default.aspx?pageid=winisdpro
  10. Vaughan Odendaal
    Aug 4, 2003
    403
    Thanks, Jack. I appreciate the explanation.
    --Sincerely,
  11. Vaughan Odendaal
    Aug 4, 2003
    403
    Jack, so if I'm understanding this, a bigger enclosure has less resistance on the driver compared to a smaller enclosure. This means more efficiency. Correct ?
    More efficiency means deeper bass ? How does this work ? If you can please explain the mechanism that allows for this I would appreciate it a lot.
    And I'm sorry if I seem like a dolt or if I'm slow or anything. I don't mean to be. Thanks in advance.
    BTW, are there any books you could recommend to me that would explain these topics in detail without going heavy into math ? I'm all for theory.
    --Sincerely,
  12. Jack Gilvey
    Mar 13, 1999
    4,948
    What little I've gathered I picked up online reading posts from folks who've forgotten more than I'll ever know. You could check out "The Loudspeaker Design Cookbook" (Vance Dickason)in the library, it's got lots of good stuff in it.
  13. Vaughan Odendaal
    Aug 4, 2003
    403
    Okay. I think I understand things a lot better now. Thank you for helping me to understand this !
    --Sincerely,
