Tom McLaughlin
- Jul 10, 2001
All, I have an HDTV ready TV, Mitsu WT-46805, and I'm about ready to start to use it at it's full potential. I understand that I can get HDTV programming OTA or through either Dish or DirectTV with Dish having more programming to date. I did read the other newbie posts that were here on the forum, but I had a few more.
The questions:
* Do I have to buy an HDTV tuner/decoder box or can I buy a satellite receiver that has this built in. It looks like from Dish you can get the model 5000, but still have to get a tuner/decoder box and a digital modulator. From what I've read, from DirectTV, I can buy the DTC100 or several other DirectTV Plus sat receivers that have the tuner/decoder built in. Is this the case??? Basically I want to know if I can go directly from a box like the DTC100 to my TV.
* I understand I have to get a dish with dual LNBs. Can I get the HDTV version of the local channels from the sat or do I have to get them OTA? From everything that I have read so far it looks like I have to get them OTA.
* If I have to get them OTA, can I get a system that receives both sat systems and takes a regular antenna input? Again, from everything I have read so far, it looks like this should not be a problem, but I just wanted to confirm.
* Could someone recommend some equipment? Basically, I want the most HDTV programming I can get, including local channels. I currently have cable which I understand I should dump. Any reasons to go Dish over Direct or the other way around other than more HDTV programming? At this point, I'm leaning toward DirectTV as it looks like I don't have to have an external tuner/decoder???
* What is digital modulator used in Dish System? Will this degrade my video signal?
* Has anyone used the SR-HD500 system from Mitsubishi?
* If I wanted to do this in phases, can I buy the sat receiver set top box, hook an antenna up to it to get the OTA programming, then later buy the dish.
* Lastly, we have a huge antenna in the attic which we don't use. It has probably been there for a long time. Can I use this for the OTA programming or do I have to get a new antenna?
Thanks for being patient and providing us newbies with all the info. What's funny is that when I talk to friends and family, they think I'm the expert...then I get on this list and feel humbled.
BTW, this forum is great. I've been reading for a long time, but this is my first post.
Tom
The questions:
Tom
