a couple of questions concerning SVS subs
Discussion in 'Archived Threads 2001-2004' started by Carl Philip, Oct 21, 2001.
  1. Carl Philip
    Carl Philip Agent
    Feb 23, 2001
    28
    hello guys
    i´m having a paradigm PS-1200 at the moment, and i´m thinking about upgrading to a SVS 25-31 CS. so first of all, will there be a big improvement?
    maybe i´ll go for a 25-31 custom-tuned to around 20-22Hz (i saw some other guy here on the forum that bought a custom-tuned SVS 25-31 sub).
    and second, do B&W 603 speakers mix well with a 25-31 sub?
    my room has the size that follows (lenght, width, height): 5 * 3.5 * 3 metres (about 17 * 12 * 10 feet i believe)
    thanks in advance
    /Carl Philip
  2. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,241
    20
    1,610
    Hi Carl,
    The 25-31cs would have more clean output >25hz than the ps1200...but it might not be a day/night difference to you as the ps1200 is actually a pretty good woof.
    How well the subwoofer blends with your full range speakers will largely depend on the crossover used,sub placement and calibration methods.(in other words...if you nail the location/calibration...it will work fine [​IMG] )
    In 2000 cu-ft, you need to decide what you're looking for from the subwoofer upgrade. If you want reference level capabilties...a single 20-31cs probably won't do it for you. Also...what brands are available locally for you? You might be better off going with something like a PW2200 or servo15 by the time shipping is factored into the SVS price,
    TV
  3. John Cain
    John Cain Second Unit
    Nov 19, 2000
    359
    Tom.
    Do you guys ever sleep???? Or take a day off????
    [​IMG]
    -- John
  4. Carl Philip
    Carl Philip Agent
    Feb 23, 2001
    28
    thanks for the response [​IMG]
    but i don´t want to play movies at reference level (75dB right?)..my neighbours would never allow that [​IMG]
    what i want is a sub that can play all the way down to 20Hz (which the ps-1200 can´t do..). what is the right choice for me then? the servo-15 is impossible to get in sweden, the only way to get one is if you find one second-hand.
    what would i benefit most from - a 20-39CS or a custom-tuned 25-31CS?
    a lot of questions for ya [​IMG]
  5. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    Just to add, in addition to the added output, I think the SVS would also sound much better than the PS-1200. When I've heard it, I've found the Paradigm to sound a bit "boomy", which I've found with other bandpass designs. The "Low-Q" SVS should have a distinct advantage there.
    [​IMG]
  6. Carl Philip
    Carl Philip Agent
    Feb 23, 2001
    28
    Jack: you´re right, that´s another reason why i wanna upgrade. the PS-1200 gets really boomy in the scenes in U-571 with the depth-charges. [​IMG]
  7. Tom Vodhanel
    Sep 4, 1998
    2,241
    20
    1,610
    If added extension is the priority over added volume...the 20-39cs/pc would be the way to go(compared to the 25-31s). Of course the 16-46s extend even deeper than the 20-39s.
    If you're pretty sure you'll be sticking with a single SV for a while...I'd go with a 16-46PC or a 20-39PC. If you feel there could be a second SVS in your future...then you should consider something like the single 20-39cs/S700 combo. This would allow an inexpensive upgrade path when you're ready for the second unit.Given your listen habits though...I'm thinking a single SV will likely suffice,
    TV
  8. Shanthi
    Shanthi Stunt Coordinator
    Aug 6, 2001
    109
    I have B&W and they blend very well.
  9. Carl Philip
    Carl Philip Agent
    Feb 23, 2001
    28
    Shanti: thanks, that´s great news for me [​IMG]
    Tom: yeah you´re right, maybe i should go for a 20-39CS instead. the 16-46 sounds like overkill for me [​IMG] (does it? hmm..we´ll see about that when i place my order)
    i just saw that the cost difference between the 25-31 and the 20-39 wasn´t that big, so i guess a 20-39CS is the way to go for me.
    i have a 120wpc 4ohm pioneer receiver that i´m not using at the moment, so i´m thinking about using it as amplification. i hope it is sufficient [​IMG]
  10. Eugene Hsieh
    Eugene Hsieh Supporting Actor
    Jun 30, 1997
    550
    I've tested the PS-1000 but not the PS-1200. I own the 25-31PC now.
    I found the PS-1000 bass laggy for music. It's much nicer on the SVS. I also love the Paradigm Servo-15, but I've never tested that one in my home because the shape of the thing was not really appropriate for my place.
    My room setup is not ideal, but with a bit of help from an equalizer, my 25-31PC does well to about 23-24 Hz according to my Radio Shack meter. After that it drops off fairly quickly (as expected).
    I never did measure the PS-1000's bass extension, but the bass quality made it irrelevant because I was not happy with its sound.
    EDIT:
    BTW, Tod,
    Do you think I would benefit from a custom tuned port for my 25-31PC? My room has a stairwell near the sub and an air duct above it [​IMG] so it definitely isn't ideal. As alluded to above I have to push up the low end bass around 25-35 Hz with my equalizer and decrease the gain up above that. I'm not so much interested in lower extension, but perhaps a flatter response. And how much does a custom port "colour" the sound?
    Eugene Hsieh, VisorCentral FAQ Editor
    1000 km on a tank of gas??? Check out the Prius and drive the future now!
    Check out my switched Dual Boot DVD Player Hack .
    [Edited last by Eugene Hsieh on October 22, 2001 at 01:53 PM]
