Steve Satch
- Apr 12, 1999
The CHT review of the nOrh has pretty much made my decision to buy the five 4.0 setup. I was deciding between these and the HTD towers. I have a couple of issues I was hoping the nOrh people could clear up before I buy. Just for background they will be paired with an Energy E:XLS10 sub (to be upgraded to an Adire or SVS within 12 months with any luck), be used for about 65-70% movies and 30-35% music in a room that is a family room with one side than completely opens into a kitchen. The combined room size is 24 feet long by 20 feet wide with a 9 and a half foot tall ceiling. The family room part where one would sit to watch movies is 24 by 13, but like I said it's open to the kitchen. Concerns: 1) Are these just not enough speaker for the room size? I assume the HTD towers would do a better job of filling the large room with sound. 2) I've heard the nOrh really should be powered by quailty gear. My power source is just a Yamaha 995 receiver and I have no plans of upgrading it. How will that sound with the nOrh 4.0? 3) What about the Energy sub? I know it's not that good. Will they sound good with it since it will be responsible for pretty much all the bass? I want to upgrade it to an SVS or Adire and have plans to. If I never did upgrade it I know the HTD towers would be able to put out lots more bass of their own than the little nOrhs. 4) Stands. I have yet to see stands for the nOrh that seem OK. I have young kids and I need STURDY stands that really fit the nOrh 4.0 like a glove for a reasonable price. The top of my TV where the center speaker will sit is about 45" off the ground. I need tall, sturdy speaker stands for the front and rear (I don't like the look of any mounted nOrh rear speakers yet) Also, how does one secure the speaker to the stand? My little Energy Take twos screw into the stand. Isn't a speaker just sitting on a stand likely to be knocked over? Thanks for any suggestions. I really would like to buy the more powerful HTD towers, but man it sounds like the nOrhs have a much better sound.
Steve
Steve
