A couple AVIA questions
Discussion in 'AV Receivers' started by BrianAe, Jun 9, 2003.
  1. BrianAe
    BrianAe Second Unit
    Dec 2, 2002
    441
    Hi all,
    I have a couple AVIA questions. I am using it to calibrate my 5.1 system composed of an Onkyo SR600 receiver and Aperion speakers.
    1) When using AVIA to find the "reference level" volume setting of your receiver, it appears that AVIA has a test to do this for each speaker and one that uses simultaneous pink noise of all speakers. Which do you use?
    2) There doesn't seem to be any documentation on the frequencies used in the subwoofer frequency sweep tests. Anyone have any ideas what tones they use?
    thanks!
  2. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    Brian,
    Use the individual speaker tones and calibrate so you get 75db on the Radio Shack meter from each one at the listening position.
    When you run the low frequency sweeps, watch the tv screen--there's a HZ readout in the upper right hand corner that shows the frequency in HZ as it sweeps down.
  3. Vin
    Vin Supporting Actor
    Oct 23, 2000
    546
    The Avia tones are actually 85db (75db for Video Essentials)....
    Vin
