96kHz/24bit DAC?
Discussion in 'Archived Threads 2001-2004' started by Sacha_C, Jan 15, 2003.
  1. Sacha_C
    Sacha_C Second Unit
    Jan 13, 2003
    294
    Does a 96kHz/24bit DAC make a big difference in sound quality? Does it work for any input or only optical/coaxial digital inputs?
  2. Jose G
    Jose G Supporting Actor
    Aug 18, 2002
    568
    If your unit has a direct mode- than it should bypass the DACs when using that mode, but if you use a digital mode, then the DACs come into play. Will good DACs improve the sound?- that depends on the source unit. If it's of lesser quality (does not have as good DAC conversion as the receiver), then it should. If it's of higher quality (has better built in DACs) then no. Also, since when using a digital mode the signal has to pass through two DAC conversions, it seems like that defeats the purpose of buying a source unit with higher quality DACs for digital output, unless you have a direct mode- which usually works for music and not HT. That's what I think, anyway.
  3. Sacha_C
    Sacha_C Second Unit
    Jan 13, 2003
    294
    I'm quite qure I'll get the sony DE885/985 receiver but the only problem is that it doesn't have a 96kHz DAC.
    I will be using the receiver mostly to listen to MP3s from my PC and DVDs.
    What type of connection from the PC to the recevier would I need to make a 96kHz DAC improve the sound of MP3s and DVDs?
    Is it worth looking for a receiver with 96kHz DACs for what I will be using it for?
  4. Brian_Tho
    Brian_Tho Stunt Coordinator
    Jan 8, 2003
    175
    It does have 96khz dacs!!!
  5. Brian_Tho
    Jan 8, 2003
    175
  6. Sacha_C
    Sacha_C Second Unit
    Jan 13, 2003
    294
    "It does have 96khz dacs!!!"
    Are you talking about the sony 885/985? Are you serious? These models have 96kHz DACs? It doesn't say that anywgere in the specs.
    Please tell me the 885/985 has 96kHz DACs!
  7. Brian_Tho
    Jan 8, 2003
    175
    Yes it does!!!! go to crutchfield pull up the specs on the 985 or 885. Hell my little sony htib receiver decodes 96khz audio!!
  8. Brian_Tho
    Jan 8, 2003
    175
    Get the 985 has more features than the 885
  9. Brian_Tho
    Jan 8, 2003
    175
    sorry to bust your bubble, but 96khz sounds the same to me as 44 or 48khz. Thats just my opinion though.
  10. Brian_Tho
    Jan 8, 2003
    175
  11. Sacha_C
    Sacha_C Second Unit
    Jan 13, 2003
    294
    "Get the 985 has more features than the 885"
    Are the only differences between the 885 and 985:
    -6.1 surround
    -Learning remote
    -OSD
    Is there anything more the 985 does?
  12. Jason GT
    Jason GT Second Unit
    Dec 12, 2002
    452
    One thing that hasn't been mentioned:
    MP3s aren't that great, soundwise. If the difference between a CD and an MP3 doesn't bother you, or if you don't even notice it, I don't think you'll find any great difference with a 96 kHz DAC.
    A 96 kHz DAC will probably not help your MP3s much, if at all (garbage in, garbage out). Besides, I don't even know if it matters, unless your receiver can actually decode MP3s.
    J
  13. Brian_Tho
    Jan 8, 2003
    175
    the mp3 player decodes the mp3 and passes the signal to the receiver. Theres not that much of a diff between cd and high bitrate mp3. I mean for god sakes lets all sit around the old home theater and count the instruments we can hear, the highs, the lows, the mids, oooh ahhh. I mean as long as the music sounds decent I am happy. I'm not into audio to that extent. Maybe Im wrong though
  14. Sacha_C
    Sacha_C Second Unit
    Jan 13, 2003
    294
    I know CDs sound a bit better than MP3s (I'll probably see a bigger difference when I get a real sound system), but It's so much easier to work with MP3s than audio CDs. My current minisystem takes 60CDs and plays mp3s off them, I can actually chosoe the CD, then the artist, then the song that I want, this makes finding songs very easy. You can't do that with audio CDs or fit 200+ songs per CD without mp3.
    I was wondering about the 96kHz for DVDs mostly.
  15. Brian_Tho
    Jan 8, 2003
    175
    Forget it, The khz is set on dvd's cannot change it. If I remeber its 48khz
  16. Jason GT
    Dec 12, 2002
    452
    I didn't mean for anybody to get defensive about MP3s [​IMG]
    My main point was that MP3 quality isn't that great, and because of that, you probably wouldn't see much if any difference from switching DACs. The bottleneck in this system comes before any sort of DAC.
    J
  17. Brian_Tho
    Jan 8, 2003
    175
    Your right Jason. Riddle me this if you never hear a sacd or dvd-a like me then mp3s sound great. i know there is better to be had. Just like the fact that mp3s are so cheap!
  18. Jason GT
    Dec 12, 2002
    452
    The difference between MP3s and CDs is pretty noticeable to me, actually, especially the garden variety 128kbps files. I am not an audiophile, nor have I heard DVD-A or SACD, but the sound difference between MP3 and CD is quite substantial IMO.
    That said, mp3s ARE convenient.
    I won't touch the cost issue of mp3s with a 1,000 km pole though [​IMG]
  19. Brian_Tho
    Jan 8, 2003
    175
    320kpbs is ok though
  20. David Lorenzo
    David Lorenzo Stunt Coordinator
    Dec 12, 2002
    198
    I agree. The difference between 320 and CD aren't that great. The MP3 format in general, though, needs to be abolished in favor of a better encoding algorithm. This won't happen though because of the huge MP3 player base that's already in circulation. There are new algorithms that are superior in quality and compression than MP3.
    As for the DAC's. If your CD player is decoding the MP3's then wouldn't it be using the player's DAC's?
